BlackHole Vu+ Duo v. 1.4.3 Multiboot
thanks
Could I put new drivers in BH 1.4.2 without any problems in future work ?
The driver upgrade is a delicate procedure.
The upgrade is possible when they not impact with current image elements.
When the drivers change radically the base image, they cannot work correctly and the direct result is the impossibility to start Enigma2 correctly.
I suggest, when new drivers are released by VuPlus, to wait some tests made by BH Team before proceed to upgrade.
If you want to try to upgrade yourself, please make a backup of current drivers located in
/lib/modules/2.6.18-7.3/extra
folder.
I know it, @angelofsky1980
As far as I know new drivers have not radicall changes compared with previous, BH 1.4.3 compared with 1.4.2 also have not radicall changes,so I just wondered is it OK to update drivers on 1.4.2 or not, short and clear question. I am not basic user.
Best regards !
