lorenzo64
BlackHole Vu+ Ultimo 1.6.6
- New Skin Rihanna 5 by Matrix10
- Extended Hdmi-Cec functions (thanks to Meo, Pieterg & Sjaaky)
- Crossepg updated from https://github.com/organizations/E2OpenPlugins (thanks to skaman)
Based on official image 6.0:
Open Embedded
- Add WebBrowser plugin
- Add UI postion control plugin
- Add 3D framebuffer control plugin
- Add remote control system code control plugin
- For details, please take a loot at git log.
Driver update
20111103(beta)
- improve DVB-C/T tuning
- Fix incorrect display of DVB-C/T SNR/AGC
- Fix high-bitrate problem in CI
- Support 3D framebuffer
- Add interface for UI position setup
- Add redundant fpga device at /dev
- Add ioctl for hdmi_cec(get physical/logical addr.)
- Fix audo mute in pass-through
- Add interface to set the system code of the remote control
- Add interface to disable REC VFD icon
- Add interface to control global alpha
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole HDMI Cec
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
