BlackHole Vu+ Uno 1.6.3 Beta DTS
lorenzo64
This beta image is dedicated to all the users that asked for DTS support (Support DTS audio codec)
New: beta drivers 20110708
- Support DTS audio codec
- Fix CI recognition problem when restart
- Fix restart crash/delay problem
New: Skin Army Wall-Hd
New: Hdmi in config (Vuuno only)
New: Manual-Fan-Control Plugin (Vuuno only)
New: Realtek R8192cu drivers added to support new Vu+ mini wifi n device.
New: Blindscan binary
New: Kernel Support for disks up to 2 Tera
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
Please, i forgot post the error to install dttusb Hawpagge WinTv stick:
[2000/01/01 01:00:45, 1] lib/account_pol.c:account_policy_get(286)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
[2000/01/01 01:00:45, 0] /Archivio/000ImVu/vuuno/build/tmp/work/mipsel-oe-linux/samba-3.0.37-r0/samba-3.0.37/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 475 is running.
This report doesen't show any kind of problem around your Ministick. There is not any kind of errors or traces about DVB-T devices in your log.
Please post the entire log produced by "dmesg" command.
For your convenient way, you can redirect the complete output of the previous command into a file and upload here the file produced.
To redirect the output use this command:
dmesg > /tmp/dmesg.txt
Works sometimes with or without smargo. Tested with 1.6.3 beta and 1.6.2, the same result.
Thanks for your work.
Regards from Spain.
