BlackHole Vu+ Uno v. 1.5 Multituner
lorenzo64
WHAT'S NEW?
Vu+ Uno drivers: 20110407
NEW NEW NEW: Dual Usb - Tuner support !!
Black Hole image support:​
- Single Usb stick dual tuner​
- Two Usb Tuner sticks same model​
-Two Usb Tuner sticks different models​
WARNING:
The shots of this presentation are from a special Vu+ Uno prototype with two P&P tuners. But the normal production box will have one P&P tuner only.
WARNING:
The new 1.5 series Black Hole images skins are not compatible with above skin versions
Vu+ uno drivers History:
20110322​
- Change file name​
20110325​
- Fix vtuner problem​
20110327​
- Fix DiseqC problem​
- Clean & speed up frontend driver(DVB-S2)​
- Set chipset info at /proc, which is 7405 with 3D​
- Fix vumodel info​
20110404​
- Clean & speed up DVB-T/C driver​
- Fix DVB-T/C detection problem(e2 booting problem)​
- Remove debug log​
- Fix VHF tuning problem(DVB-T)​
- Fix SNR/AGC display(DVB-T/C)​
- Fix DVB-S2 tuning problem(occurred only in some channels)​
20110407​
- Fix no audio problem at radio channel​
- Fix AGC in DVB-S​
- Change remote control type to advanced(Needs a config.misc.rcused=0 at​
/etc/enigma2/settings)​
- Change the model name(Reinstall of some plug-ins are needed)​
- Fix BER problem(positioner plugin)​
- Remove static udev devices(Needs a new image)​
Added WiFi B/G/N USB dongle Realtek 8712 driver (list of supported devices here)
WARNING:
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Crediits
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
Hi angelofsky1980,
i am curious so i ask again: How things are going on with USB Tuner DVBS2 on SD and HD channels. Are there only problems for HD? Or also on SD? Are the SD channels working 100% and stable??
cu
KJ
Hi angelofsky1980,
cu
KJ
We have implemented the DVB-S2 suport but sme tests are in progress but seems to work almost stable.
