Blindscan Plugin for Vu Uno 4k
bala240
Please let me know when a blindscan plugin is available for Vu Uno 4k. Until that time my Vu Uno 4k can rest in store. It is useless for me as far as I care. Regards
By the way, if you have unicable LNB, it does not solve the problem of ...
VU + Uno4K
VU + Solo4K
VU + Ultimo4K
The VU + DUO2 works well with the blind search with normal LNB, with unicable LNB does not find anything by the operation of these LNB, which is logical.
Por cierto, si tienes LNB unicable, da igual que solucionen el problema del ...
VU+Uno4K
VU+Solo4K
VU+Ultimo4K
El VU+DUO2 funciona bien con la busqueda ciega con LNB normales, con LNB unicable no encuentra nada por el funcionamiento de estos LNB, que es logica.
Checked out with Solo4K and Ultimo4K, the Uno4K has the same tuner as the Ultimo4K/Verificado con el Solo4K y Ultimo4K, el Uno4K tiene el mismo sintonizador que el Ultimo4K.
