blindscan question on vu+ duo 2
iwols
hi all on a previous thread i was told vu+duo 2 has blindscan but the solo 2 ,does not,if that is correct then ,is it possible that when doing a blindscan can you only use 1 tuner or can you set 1 tuner to scan the verticals while the other tuner blindscans the horizontals,or am i talking the impossible thanks guys
