Blinking clock or indication of record process
Don Andres
BH Lover
Hi ,
Is there any posibility to activate either " Blinking Clock" in display or Red light in BH 2.0.5 or any indication for upgoing recording ? Have activated "ON" - "show blinking clock in display during recording" in Customise menu , but this doesn't work for me ?!
Hi ,
It will blink if your STB on standby ,while its recording!
Well,
Thx for the sugesion :)
Have tried manual recording and "timer" , receiver is in Stand-bye , no sign of blinking clock .
Thought maybe this is skin related , changed to default skin , same result .
I'm using Neutrino key ltayout , have also tried to switch in "Paulli" to E2 setting , same negative result .
Runnins out for ideas ......
Is not main skin problem but problem in py coding and VFD skin coding
You can change in skin_user.xml in /etc/enigma2/
if you replace :
<convert type="ConditionalShowHide"/>
to
<convert type="ConditionalShowHide">Blink</convert>
Example Standby
<screen name="StandbySummary" position="0,0" size="140,32" id="1">
<widget source="global.CurrentTime" render="Label" position="13,10" size="90,22" font="VFD;28" halign="right" valign="center" transparent="1">
<convert type="ClockToText">Format:%H:%M</convert>
</widget>
<widget source="global.CurrentTime" render="Label" position="105,10" zPosition="1" size="40,16" font="VFD;16" halign="left" valign="top" transparent="1">
<convert type="ClockToText">Format:%S</convert>
</widget>
<widget source="session.RecordState" render="Pixmap" pixmap="vfd_icons/rec.png" position="123,0" size="15,9">
</widget>
</screen>
