box crashing after update
netguy
hi guys vu duo2 running obh 06 crashing this evening after update after every crash update light still flashes i have crash log if someone could have a look see what it is thanks if so where do i put it
Zip it and upload it here.
same as on my duo2 did an update green yellow box crashed still flasing light on the front of the box display
hope i did it right log from my duo2 crash update light flashes
There is an momentary issue with software update.
In order to solve your issue, you can wait until its fixed or by using telnet, enter the following commands ( one by one ):
killall -9 enigma2
opkg update && opkg upgrade
reboot
why don't the guy check every thing before releasing any image its comen sense hear in the uk
like any thing else sir u get what u out in please can u start testing inages please
Sorry, but your comments are :offtopic:
1. I´ve confirmed the issue, before your post.
2. I´ve not yet time to report to the team.
3. I´ve looked in Git and it has a commit for fix this BSOD --> https://github.com/BlackHole/enigma2-1/commit/4c3ac46375f1e43ca2b17108c37fbf94d940b456
$ before your comments i´ve posted a solution for upgrading your STB ( if you want ).
Note: My Duo2 ( same model you own ), was updated with the solution i told.
If you haven´t read my post ... take a look to it --> http://www.vuplus-community.net/board/threads/box-crashing-after-update.29520/#post-214955
To let you know all images are "hardly tested" before release. This is not a problem of a not tested release, but indeed an issue that becomes due to an "general update".
