Box green screens and reboots in loop, need HELP!!!
Sorry, I'm new to this world, this evening I had an error loop with webinterface (I set up the same port for http and https access and I think this caused the green loop screen, however the error is "Address already in use"), my problem is that I don't know anything about telnet and how to access the vu+solo during that loop screen, there is a way to stop that loop screen, remove webinterface plugin and try to download it again ? Thanks a lot
You can reflash your box and all come back to default settings with different ports for HTTP and HTTPS settings.
Thank you, after the reflash, if I'll enable the security access through the web interface, which user/pass I'll have to use? I've vu+solo with black hole 1.6.6
User = root
Password = your password.
You must set up a password before use auth into webif.
Thanks for your help. The last thing, to change the defaul pwd I have to download a plugin? I saw a plugin called root password changer or something like that.
You can change it via telnet command or via the plugin you have wrote.
You can download it via Addon Download Manager into BH image.
Hi there can someone help me please with this green screen crashlog please... I have attached a file.. PLEASE HELP !!
How can I work without it please !?? Sorry I am still green in technical faults
This is not technical fault
but the violation of forum rules
It is not allowed discussion of illegal watching satellite TV
Sorry you have BAN 7 days to read forum rules.
