box randomly turns off to standby mode
gmx
hi guys
just recently box has started to turn itself off into standby mode! its occurs more often if i have HDMI CEC turned on, but still does it less frequently of hdmi cec turned off.
currently running latest version of open black hole, recently upgraded from previous version to try and rectify the fault, but still the same after upgrade.
any ideas guys?
hi guys
any ideas guys?
Wich STB model?
Skin used?
Any crashlog?
Image version used?
that info would help lol
Wich STB model? vu duo 2
Skin used? default skin
Any crashlog? no crashlog
cheers
Are you shure?
Have you checked --> /home/root/logs or /media/hdd/logs ??
Try Ftp your STB, and check it.
ok just an update, installed another image and problems persist, contacted suppler and awaiting reply now.
