Box wont boot please help - Urgent
Duo2User666
Hello,
Just said yes to a upgrade message on a skin and it seems to have taken out my box.
It boots to the starting gui screen and just sits there, i still have FTP and Telnet access to it.
I have tried to just delete the offending skin from usr/share/enigma2 however no joy
I was also playing around trying to scan other tuners this morning however the box was quite happy until i undated the skin and it asked to reboot the GUI. So i presume that is the issue.
Any ideas, are there log files i can check or a better way to reset the GUI?
Thanks
Hello,
Thanks
We warned a hundred times does not use skins
which have not been made strictly for BH image.
Now you have to install image again If deletion from particular skin did not help.
This was a BH written skin, is there any debugging i can do?
I read in another post that you put HD Glas 16
this is not skin which have been made strictly for BH image.
This skin uses its python coding.
If I understand you're deleted skin
but not deleted other additions that this skin put in the image
which can cause crash of image
If so
Then only helps re-flash image .
If there is a crash log you can find in /hdd all crash logs
and try to fix error
