Uno Brick after thunderstorm, any help appreciated
mendicm
Hello! I'm so sad ;( my Vu+ uno died on thunderstorm. I did some tests but no luck, can anyone say his opinion?
What happens when I turn on my Vu+:
It shows strange characters on display for a while and power led change his intensity. After a while all dissapears on lcd and led stays on but at very low intensity.
Tests:
PSU: Ok, all lines at +12v.
Flash BH from USB: nope, it even try to read the pendrive.
Flash VU+ image from rs232: Nope, vu-utility doesn't find the box.
Hypervisor at rs232: no output from the box.
I think that the problem is a corrupt CFE but not sure. Is maybe the Bcm97413 burned or any other component?
My only hope is to try a JTAG reflash but I need to buy cypress interface. Do you think that worth?
Thank you!
PD: I tried comunication with arduino i2c port but without any documentation about the Bcm97413 i2c protocol no luck :fie:
check your connection on LNB. if it is short circuit caused by storm, the system will shutdown automatically.
Now I'm running on old dm500 and Lnb is ok. I tried removing the sat module from vu+ and no luck.
Psu is ok too, 12v output
Hello. I have the same problem. Another day was a thunderstorm. What did you do at least? what was the solution for your problem? thanks
