Bug recording vu+duo2 BH 3.0.1
behja
Hello,
I need a help if some one can resolve my problem as follow:
when i want to record a channel ,my reciever send me message:
In order to record an mission programed ,the tv will zap to recording channel!
When i check there is no recording en stand by anywhere
Thanks
Friend reason this error is alot :
- maybe your image is corupoted
- you setup permanet record
- you have no mounted hdd
- others …..
But i think best will be to you chnage to last version image BH 3.0.6
Your Bh have more 2 years from this time was alot driver realsed and bug fixed.
Best is start from begined from new image setup etc.
Hello,
Thanks
I suppose you are talking about timer programmed recordings, not direct recording, aren't you? Because this is a message you usually get programming a timer with the option "Zap and record".
What happens if you just set a timer for a recording only action?
But, OVERALL... if you have just one tuner and you want to record from a channel while another recordings is going on, you won't be able to do.
So, explain you system and your tuner configuration.
Hi Alexwillmac,
Both actions do not work whether direct recording (timer) or differing record.
My box already has a twin tuners.
The problem that the box supports this action but does'nt execute it!?
Apart from what bogdamn said (that your box was "hacked" and someone uses it for streaming and then uses a tuner) if we don't know how you configured your tuners, we cannot go further with hypothesis.
Grab that configuration, something like in the attached picture, and send it.
Hi,
With some actions i resolve my problem as follows
Main menu-Set up-Systeme-Personalize
recording first i changed yes with no then and i tried to record so all works well.
i changed again recording first no by yes and also recording works well.
I think it's only a receiver bug .
I close this matter thanking evryone has been interested to my problem
