Building Open Black Hole
jucaroba
Hello
I want to build my own Open Black Hole image.
I do:
$ git clone http://git.vuplus-community.net/git/openblackhole/openblackhole-oe-core.git
$ cd openblackhole-oe-core
$ MACHINE=vuzero make image
but the build process can not download the opera-hbbtv_20150622_0.tar.gz file. How is it supposed I have to build an own image? If the previous file is not distributable, can someone with enough "privileges", at least, give me a list of its contents to be able to create an equivalent tarball from the files in my Black Hole image?
Thanks in advance
I'm trying to solve this issue too, for me remains a mystery how an open source project is so secretive and badly documented even for a first build.
From the other forums I only get no sense answers or silence...
What is the point of removing hbbtv browser and update a bunch of dependencies? You should spend your time improving code not debugging the build chain...
git answer "fatal: repository not found"
git clone http://git.vuplus-community.net/git/openblackhole/openblackhole-enigma2.git
git clone http://git.vuplus-community.net/git/openblackhole/openmultiboot.git
git clone http://git.vuplus-community.net/git/openblackhole/openmultibootmanager.git
how to download ?
I tried the following options but also did not help
git clone https://git.vuplus-community.net/git/openblackhole/openblackhole-enigma2.git fatal: repository not found
git clone https://git.vuplus-community.net/openblackhole/openblackhole-enigma2.git fatal: repository not found
git clone http://git.vuplus-community.net/git/openblackhole/openblackhole-enigma2.git fatal: repository not found
git clone http://git.vuplus-community.net/openblackhole/openblackhole-enigma2.git fatal: repository not found
git clone git://vuplus-community.net/git/openblackhole/openblackhole-enigma2.git fatal: unable to connect to vuplus-community.net fatal: errno=Connection timed out
git clone git://vuplus-community.net/openblackhole/openblackhole-enigma2.git fatal: unable to connect to vuplus-community.net fatal: errno=Connection timed out
Openblackhole is part of oe-alliance.
Goto Github oealliance and follow instructions to build openblackhole distro.
