Solo2 Burnt chip Vu+ Solo2
Eusebio20
Friends of the Forum, I have a Vu+ Solo2 equipment, with a burned chip, some colleague, will have the electronic plane of this equipment or could indicate me the code of the same to see if I can rescue this equipment.
I attach the photos of the chip, which is partially burned, additionally there are 2 more damaged components, thanking you in advance for your help.
Matrix10
I don't believe anyone has an electronic diagram
solo 2
However, I managed to find for you on the Internet which chip it is LNBH26L
It is the chip that sends commands to the LNB
You probably had an electrostatic lightning strike nearby.
The other two components are coils
probably around 13 nH, at least that's how it is on the lnbh26l chip protection diagram.
I think the value is not critical.
You should also check the Transient voltage suppressor (TVS diode) next to the chip with code S10, which serves to protect against static electricity.
You can find some of these TVS diode components here
https://eu.mouser.com/c/ds/circuit-protection/esd-suppressors-tvs-diodes/?q=S10
  • lnbh26l.pdf
