Cablescan like pli
Kevin9500
Hi all,
Does openblackhole has a cable scan option like the pli image?
I tried the black hole image and there I can't find it.
I know how to scan,but when I scan the channels they are mixed,but when I use cable scan it is sorted.
Regards.
Hello, I got the same problem. I'm looking for the possibility to enter a cable ID to perform an automatic search (channel would be automatically in the right order). Thank you in advance.
