Can I connect another stb to vu+?
Michael_Knight
Can I connect another stb to my Vu+(uno 4k se)? I connected another stb using hdmi but I am not able to see anything related to other stb. Pressing on "AV" button on the vu+ remote doesn't do anything.
Press the blue button (continuing to press) until the respective menu appears. Enable "HDMI IN" pressing key 1 - to activate it, to disable it, key 1 again.
Thanks for your answer, it works. When I try to record from Hdmi In , the record is very problematic, it basically can't record, I think it is cause the other stb is using smartcard for decoding, so I think there is no way to record it...
It won't be for that ... something about this is around:
HTML:
https://www.vuplus-community.net/board/threads/vuplus-4k-hdmi-in-peculiarit%C3%A0.40225/#post-266138
The other STB where you have the card is E2?
Thanks for your answer.I've looked at the webpage you gave, unfortunately it's not possible for now if I understand it correctly.
The other stb is not E2, I think it is a closed source stb which was given by a broadcaster platform.
I am thinking about switching to "module subscription" of the same broadcaster , so I will directly put the module into Vu+, I hope it can record the same channels in this way...
I had thought it was cause of encryption, but I tried connecting just an old dvd recorder/player , I tried to record what the dvd player played but it still couldn't record.So it can't record anything from hdmi-in port I think.
