Can I watch a program and record another with Vu+ receivers ?
valdemirs
I only use Cable system.
Which model do you recommend to me ?
Yes, but
The channels must are on the same frequency.
Or, you have a STB with 2 Cable tunners ( in your particular case )
With no dought i´ll recomend VU+ DUO2 .... and join the club owners ... like me!:welcome::thanks:
You can in option add a second cable tuner ....
or add a twin sat tunner because there are 2 slots for that.
