Can the Vu+ Duo match my Topfield 5800?
m-vs1
Very keen to buy one of these, but I need to know if it will do any of the following. Help is v much appreciated:
1. with a Hdd does the VU+ record to a buffer without having to tell it to record, so that I can rewind TV. Handy if I miss something - my current pvr (topfield 5800) records 1hr of the current channel to buffer)
2. Can I then choose to record that programme from the beginning?
3. What format does it record in - need to edit programmes on TV (I'm a teacher so use snippets in class)
4. Is it possible to jump forward and backwards a predetermined number of seconds/minutes to skip adverts?
Many thanks
Barry
There is a plug called permanent time shift,,,,U can download and use it for that purpose ( I think it record to the Hard Disk)
I do not know,never used that plug in.
I think its .TS format (search google for more detail of this format)
Yes...!
In conclusion VU+ is very powerful STB.
A
nd with BH image installed on it, that will make the STB>>> User Friendly and a lot of FUN .
Many thanks
Barry
