Duo2 Cannot get DVB-T to work
MUTU
Hi,
I bought a Duo2 and installed Black Hole. I connected DVB-S to Tuner A and my DVB-T antenna to Tuner B. Tuner A is set as satellite, but how do I configure the second tuner to work as DVB-T? In the options I have simple, positional and advanced, but nothing to change the tuner type to DVB-T.
It seems you have a dual sat tuner (DVB-S).
Therefore, you can connect only sat antennas.
You need to add a DVB-T tuner for DTT.
You can use an internal tuner or a usb tuner.
