fredphoesh
Hello people,
I was trying to set up OpenVPN on my Solo2 box (openvix), and had copied the four files to the etc/openvpn/ folder, but when I reboot it never gets past the openvix splash screen, and I also cannot access the box via FTP as I get this message: 'Connection attempt failed with "ECONNREFUSED - Connection refused by server".'
Is there some way you know of that will enable me to not be refused by the box so I can remove the files I added?
Thanks!
Mark.
Thanks!
Mark.
