Hi Everyone, Would there be anyone who could help me get this sorted?
I have a VU+solo2 and I'm trying to import all channels on the Optus C1/D3 satelittle but I can only seem to find the FTA stuff . I'm really not sure of the correct settings I should be using when I do the scan so any help there would be great. Manny Thanks.
Here is what I done so far:
Installed the latest image of BH and other needed software
I have changed the satelittle .mxl file in the VU+ to include the Optus C1/D3 Sat see below.
<sat name="156.0E Optus C1/D3" flags="0" position="1560">
<transponder frequency="11720000" symbol_rate="29455000" polarization="0" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="11762000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="11886000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="11928000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="11969000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12011000" symbol_rate="29455000" polarization="0" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12011000" symbol_rate="27800000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12052000" symbol_rate="29455000" polarization="0" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12052000" symbol_rate="27800000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12094000" symbol_rate="29455000" polarization="0" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12094000" symbol_rate="27800000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12136000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12136000" symbol_rate="27800000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12177000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12177000" symbol_rate="27800000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12305000" symbol_rate="30000000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12358000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12369000" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12398000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12407000" symbol_rate="30000000" polarization="1" fec_inner="2" system="0" modulation="1"/>
<transponder frequency="12438000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12478000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12487000" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12518000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12527000" symbol_rate="30000000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12558000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12567000" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12598000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12638000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12647000" symbol_rate="30000000" polarization="1" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="12689000" symbol_rate="27800000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12728000" symbol_rate="24450000" polarization="1" fec_inner="1" system="0" modulation="1"/>
Manny Thanks.
Manny Thanks.
