Can't stream some channels - MPTS, multicast
addams
Hello,
I'm facing a serious problem to stream some channels (dvb-s2) to my local network (smart tv, or VLC on pc/mobile).
The problem occurs on different vu+ receivers and differents images (latest OH, OBH, OpenPLI).
Note : I can record these channels
the stream come from webif and looks like this :
http://192.168.0.10:8001/1:0:1:208:27:36:CE40000:0:0:0:
After many search I discovery that BSPplayer can open these problematic streams. He take a little longer but he can open them.
Here is the stream properties of a problematic stream :
It seems that the stream have may tracks/stream. The most players can't open it, but BSPPlayer take a little longer but open it, it seem that he did a loop the find the stream with data.
A 'normal' stream :
Only one track for video/audio. I can open it on all players.
Is this problem new ? I found many old information about MPTS, multicast channels but I don't know if there is a link.
Have someone a workaround to solve this problem ?
This seems to be a video stream malformed from portuguese provider in hispasat.
I found many links about this issue :
https://github.com/google/ExoPlayer/issues/7052
https://trac.videolan.org/vlc/ticket/24258#no1
https://github.com/kodi-pvr/pvr.vuplus/issues/208
https://github.com/kodi-pvr/pvr.vuplus/issues/219
https://github.com/kodi-pvr/pvr.vuplus/issues/231
https://github.com/xbmc/xbmc/pull/16244
https://github.com/xbmc/xbmc/pull/16314
Kodi, MPC, BPSplayer can open it, but others players don't.
is there any solution to send a 'correct' stream from the vu+ ?
regards
Well, there are already some that open, it's not all bad! This is more than discussed ... on the PC, in addition to the ones that open, use PotPlayer ... on the smartphone use the tiMote app with BSPlayer. As for non-Android smartvs in the past, I already had this working to test but I don't remember what I did ... You say that Kodi, MPC and BSPlayer can open it, what do you want more?
hi,
I just want understand what it happening :) and if possible, get it working back without buy more android boxes
The most of the players (android/ios) are impacted, specialy those who access the enigma2 receivers directly.
