Card PT
Duplobox
Hello , I bought a vu + zero 4k and I have a card from the carrier PT but the same does not work.
I can not receive / share placements from the card.
I'm using the image open black hole
I leave here the ***** log to try to figure out the problem.
2018/01/05 19:41:49 395557C9 r (reader) miau [internal] card detected
2018/01/05 19:41:49 395557C9 r (reader) miau [internal] ATR:
2018/01/05 19:41:49 395557C9 r (reader) miau [internal] Init card protocol T0, FI=1, F=372, D=1, N=1
2018/01/05 19:41:49 395557C9 r (reader) miau [internal] Calculated work ETU is 82.67 us reader mhz = 450
2018/01/05 19:41:50 395557C9 r (reader) miau [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
2018/01/05 19:41:51 395557C9 r (reader) miau [internal] detect seca/nagra tunneled card
2018/01/05 19:41:57 395557C9 r (reader) miau [internal] card system not supported
2018/01/05 19:41:57 395557C9 r (reader) miau [internal] Normal mode failed, reverting to Deprecated Mode
2018/01/05 19:41:58 395557C9 r (reader) miau [internal] ATR:
2018/01/05 19:41:58 395557C9 r (reader) miau [internal] Init card protocol T0, FI=1, F=372, D=1, N=1
2018/01/05 19:41:58 395557C9 r (reader) miau [internal] Calculated work ETU is 82.67 us reader mhz = 450
2018/01/05 19:41:59 395557C9 r (reader) miau [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
2018/01/05 19:42:00 395557C9 r (reader) miau [internal] detect seca/nagra tunneled card
2018/01/05 19:42:06 395557C9 r (reader) miau [internal] card system not supported
2018/01/05 19:42:06 395557C9 r (reader) miau [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
2018/01/05 19:42:06 395557C9 r (reader) miau [internal] card initializing error
