you're getting trouble in your card reader. Can you confirm what the error is so I can help please? I also faced similar problem with my card and after searching online I came through online instructions and my problem was solved.
For your more convenience I am attaching infograph on the subject, which will be helpful to you. In case you still face any problem you can also visit here.
