Catsey settings Green Screen Crash
digicon
Hi,
Just upgraded to 1.7.7 already done the FPGA upgrade have only installed Latest Catseye channel list and every time i select BBCHD on 28.2° east it crashes, I have never had this problem with any other version and tuner config is setup identical to previous versions
Not happy
Hi,
Not happy
Try another set of settings.
i already did that i even tried the old settings from the server dated 12-08-2012 and it still green screens with just a basic install
Hi,
Not happy
I am experiencing same problem like you my friend with the same settings,and even on other sats like 13 east and 9 east.....lets try to use other settings to test
I tried latest of vhannibal and the problem looks that solved,at the moment i am going to talk with Catseye to check and fix the list ;)
I am using other settings ,vhannibal or Mbrincats(Mbrincats settings are very good,but he made them for our footprints only).I think the problem was between the image and Catseye's,i wrote him,but he tells me that he didn't find any errors with his lists when he checked. Now i am working very good with the latset BH 1.77B,and i am waiting for the BH 1.78 thanks to our Great Team :notworthy:
Even the Latest Catseye channel list still has problems with the latest BH 1.7.7 versions , all other BH images work fine with catseye settings.
he did mention that he puts the Vid/Aud pids in his channels where as Vhannibal does not.
Update :- I have done a full Service Searching/Automatic Scan and I have found that this has worked for me using Catseyes channel list. Thanks for all the advice Guys/Gals
