Catseye motor settings help
freezefm
Hi i have a vu+ duo2 with blackhole image, i have downloaded the latest catseye motor settings from there website as they are not available yet on the blackhole settings tab on sat box, my question is how do i install these files, if anyone could give me a step by step guide on how to do this i would be greatful, thankyou
Try dreamboxedit:
http://www.vuplus-community.net/board/threads/dreamboxedit.18975/
If you haven't used this before, set up a folder, called Settings, on your PC desktop, as this is the default storage name, and location.
Start up dreamboxedit, go to Tools, and click on Options.
Put your receivers IP Address, in the relevant IP address box and then save.
Now try opening the Catseye list, File, Open.
If you're happy with the list, and don't want to make any changes, FTP it to your receiver.
make sure you have the correct version, of the catseye list.
Try dreamboxedit:
Thankyou so much for your help!!! this worked perfectly, once again i have learned something new from a helpful community :)
