CCTV
coopernokia
I have a VU+Solo2 box, I recently bought a CCTV system for my house which can be accessed online via phones and computers etc.
Is there any way I can view it using my VU+? It is on the same wired network to if that helps?
Thanks in advance for any feedback
Try the plugin 'camoFS' available via the feeds, If your camera is supported you'll see a camera-window on movement detection, if your camera has movement detection, And The camera must provide mpeg2/4 streams
