cfe_cfe_auto.bin skipping ... file not found
vps212
hello i have vu+solo when i try flash with all image solo i have this message
i tryed update booload not result
i try all image no result
please can you help me please
attachment.php
and when i reboot after flash i have that
attachment.php
i wait your replay thanx
During image flash process the message is not a problem because into image zip file there is not present the CFE update file.
During CFE flash it's very problematic if appear that message because you haven't prepared correctly the USB stick.
Unzip the CFE zip file and put the vuplus fodler into a FAT32 formatted USB stick and retry the flash process.
hello thanx for you replay then this message its normal ,?
i use 3 usb clé format fat32 and i trayed diffrent image but in finaly i have on only led green but no image
i wait you replay thanx
this is the first time I trusted this brand because before I bought that dremabox and I hope that the vu+not disappoint me
i think too that you didn't extract properly the folder vu plus into the pen drive...result that the dec cannot found the file to update the bootloader..
