Change ftp port
Ardito
Does anyone knows if there is a way to change the default ftp port into BH image from default 21 to another of my choice?
My provider uses port 21 for voip and my router can't remap to another port (and I can't replace it without losing voip...).
Thanks in advance!
Thanks in advance!
I hope to be proved wrong but i think that yuo can't because is fixed.
The port number is defined in /etc/services. So change the port number then disable/enable ftp (blue -> blue -> ftp panel)
Default entry in /etc/services for ftp is
ftp            21/tcp
Change 21 to something else, e.g. 1021
ftp            1021/tcp
