I use + or - button to call the channel list.
When I choose the channel from the list and push "OK" button the list of channels disappears. And I see the channel in a full secrren mode. Is it possible (by any plugin, skin or any control set) to change this behavior? And don't hide the list of channels after pressing "OK". I mean to remain in the list and display the choosen programme in preview mode (like after pushing + or - firstly).
Yes, I assume you are using Black Hole image as you are on the Black Hole board ?
Press green button and then yellow button to access addons, of course you box must be connected to the internet.
Sure. I'm using BH 1.6.6. Pauli Neutrino plugin changes only button.
But the question was about interface. Is it possible don't hide the channel list when I press "OK"?
The sonc explained (the post above). To keep @Channel list on screen when press OK. Just changes the channel in the PIG (small pictore or picture on backgrounf. Depends on skin).
