Changing Kodi Skin....?
dabezt
is it possible to change Kodi (the one in vuplus solo2 BH release) skins?
I get errors anytime... Thnx!
Thanks dude... I'm able to install different skins to Kodi on vuplus solo2 with BH 3.0.2.G... but I'm getting errors in the main Movies 'screen' like "error loading bookmarks" "error loading new movies links" etc...
Same on TV Shows main screen...
The latest added movies or tv shows Cover are not shown...
Cheers!
For example, I've installed Aeon Nox skin, and when I activate this skin for example I get two erroes:
Error toolbox script
Error Skin Shortcuts (this is the one I get with every skin but Confluence)
Seem like some python librares are not there....
The log file comes here:
20:16:45 T:1984860160  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:16:45 T:1984860160  NOTICE: -----------------------------------------------------------------------
20:16:45 T:1984860160  NOTICE: Starting Kodi (16.1-RC2 Git:2016-04-06-528f9f8-dirty). Platform: Linux MIPS 32-bit
20:16:45 T:1984860160  NOTICE: Using Release Kodi x32 build
20:16:45 T:1984860160  NOTICE: Kodi compiled Apr  6 2016 by GCC 4.9.2 for Linux MIPS 32-bit version 3.19.0 (201472)
20:16:45 T:1984860160  NOTICE: Running on Unknown Linux Distribution 0.0, kernel: Linux MIPS 32-bit version 3.13.5
20:16:45 T:1984860160  NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
20:16:45 T:1984860160  NOTICE: Host CPU: BCM7346B2 STB platform, 2 cores available
20:16:45 T:1984860160  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:16:45 T:1984860160  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:16:45 T:1984860160  NOTICE: special://masterprofile/ is mapped to: /media/hdd/.kodi/userdata
20:16:45 T:1984860160  NOTICE: special://home/ is mapped to: /media/hdd/.kodi
20:16:45 T:1984860160  NOTICE: special://temp/ is mapped to: /tmp/kodi
20:16:45 T:1984860160  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:16:45 T:1984860160  NOTICE: Local hostname: vusolo2
20:16:45 T:1984860160  NOTICE: Log File is located: /tmp/kodi/kodi.log
20:16:45 T:1984860160 WARNING: Unicode properties are not enabled in PCRE lib, support for national symbols may be limited!
20:16:45 T:1984860160  NOTICE: Consider installing PCRE lib version 8.10 or later with enabled Unicode properties and UTF-8 support. Your PCRE lib version: 8.36 2014-09-26
20:16:45 T:1984860160  NOTICE: load settings...
20:16:45 T:1984860160 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
20:16:45 T:1984860160  NOTICE: Change AESink retry count..
20:16:45 T:1984860160  NOTICE: AESink retry count - 1
20:16:45 T:1984860160  NOTICE: No Devices found - retry: 1
20:16:46 T:1984860160  NOTICE: Found 0 Lists of Devices
20:16:46 T:1984860160  NOTICE: Change AESink retry count..
20:16:46 T:1984860160  NOTICE: AESink retry count - 1
20:16:46 T:1984860160  NOTICE: No Devices found - retry: 1
20:16:48 T:1984860160  NOTICE: Found 0 Lists of Devices
20:16:48 T:1984860160  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:16:48 T:1984860160  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:16:48 T:1984860160  NOTICE: Default DVD Player: dvdplayer
20:16:48 T:1984860160  NOTICE: Default Video Player: dvdplayer
20:16:48 T:1984860160  NOTICE: Default Audio Player: paplayer
20:16:48 T:1984860160  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:16:48 T:1984860160  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:16:48 T:1984860160  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:16:48 T:1984860160  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:16:48 T:1984860160  NOTICE: Loaded playercorefactory configuration
20:16:48 T:1984860160  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:16:48 T:1984860160  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:16:48 T:1984726096  NOTICE: Change AESink retry count..
18:16:48 T:1984726096  NOTICE: AESink retry count - 1
18:16:48 T:1984726096  NOTICE: No Devices found - retry: 1
18:16:49 T:1984726096  NOTICE: Found 0 Lists of Devices
18:16:49 T:1984860160  NOTICE: Running database version Addons20
18:16:50 T:1984860160  NOTICE: ADDONS: Using repository repository.xbmc.org
18:16:50 T:1984860160  NOTICE: InitWindowSystem: Using EGL Implementation: vuplus
18:16:50 T:1984860160  NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
18:16:50 T:1984860160  NOTICE: Previous line repeats 2 times.
18:16:50 T:1984860160  NOTICE: Found (1280x720@50.000000) at 16, setting to RES_DESKTOP at 16
18:16:50 T:1984860160  NOTICE: Checking resolution 16
18:16:50 T:1984860160  NOTICE: GL_VENDOR = Broadcom
18:16:50 T:1984860160  NOTICE: GL_RENDERER = VideoCore IV HW (V3D-410)
18:16:50 T:1984860160  NOTICE: GL_VERSION = OpenGL ES 2.0
18:16:50 T:1984860160  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:16:50 T:1984860160  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888
18:16:51 T:1984860160  NOTICE: Running database version Addons20
18:16:51 T:1984860160  NOTICE: Running database version ViewModes6
18:16:51 T:1984860160  NOTICE: Running database version Textures13
18:16:51 T:1984860160  NOTICE: Running database version MyMusic56
18:16:51 T:1984860160  NOTICE: Running database version MyVideos99
18:16:51 T:1984860160  NOTICE: Running database version TV29
18:16:51 T:1984860160  NOTICE: Running database version Epg11
18:16:53 T:1984860160 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:16:53 T:1984860160 WARNING: Skin has invalid include: skinshortcuts-submenu
18:16:54 T:1984860160  NOTICE: ActiveAE DSP - starting
18:16:54 T:1984860160  NOTICE: initialize done
18:16:54 T:1984860160  NOTICE: Running the application...
18:16:54 T:1984860160  NOTICE: starting zeroconf publishing
18:16:54 T:1984860160  NOTICE: WebServer: Started the webserver
18:16:54 T:1984860160  NOTICE: starting upnp client
18:16:54 T:1516237904  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:16:54 T:1516237904  NOTICE: UDP: Listening on port 9777
18:16:54 T:1984860160 WARNING: no keymap support (requires /dev/tty0 - CONFIG_VT)
18:16:57 T:1654649936 WARNING: Previous line repeats 1 times.
18:16:57 T:1654649936   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <type 'exceptions.ImportError'>
                                            Error Contents: No module named PIL
                                              File "/media/hdd/.kodi/addons/script.toolbox/default.py", line 6, in <module>
                                                from resources.lib.Utils import *
                                              File "/media/hdd/.kodi/addons/script.toolbox/resources/lib/Utils.py", line 9, in <module>
                                                from PIL import Image, ImageOps
                                            ImportError: No module named PIL
                                            -->End of Python script error report<--
18:16:58 T:1673462864  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
18:17:01 T:1698628688  NOTICE: script.grab.fanart: Grab Fanart Service Started
18:17:05 T:1627341904   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Contents: No module named cProfile
                                              File "/media/hdd/.kodi/addons/script.skinshortcuts/default.py", line 6, in <module>
                                                import cProfile
                                            ImportError: No module named cProfile
18:17:05 T:1681851472  NOTICE: Skin Helper Service --> skin helper service version 1.0.100 started
18:17:05 T:1681851472  NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
18:17:11 T:1474294864  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:11 T:1474294864  NOTICE: version 4.6.1 started
18:17:21 T:1654649936  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:21 T:1654649936  NOTICE: version 4.6.1 started
18:17:30 T:1654649936 WARNING: Attempt to use invalid handle 4
18:17:30 T:1654649936 WARNING: Previous line repeats 29 times.
18:17:30 T:1654649936  NOTICE: finished
18:17:34 T:1474294864 WARNING: Attempt to use invalid handle 3
18:17:34 T:1474294864 WARNING: Previous line repeats 29 times.
18:17:34 T:1474294864  NOTICE: finished
18:17:35 T:1644119120   ERROR: GetDirectory - Error getting include
18:17:35 T:1440740432  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:36 T:1440740432  NOTICE: version 4.6.1 started
18:17:41 T:1440740432 WARNING: Attempt to use invalid handle 5
18:17:41 T:1440740432 WARNING: Previous line repeats 29 times.
18:17:41 T:1440740432  NOTICE: finished
18:17:47 T:1465906256  NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
18:17:47 T:1465906256  NOTICE: version 4.6.1 started
18:17:51 T:1465906256 WARNING: Attempt to use invalid handle 6
18:17:51 T:1465906256 WARNING: Previous line repeats 29 times.
18:17:51 T:1465906256  NOTICE: finished
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=207932
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=258230
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=302946
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=343611
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=286567
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=339408
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=412467
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=374251
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=377447
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=375183
18:17:52 T:1644119120   ERROR: InputStream: Error opening, plugin://script.extendedinfo/?info=extendedinfo&&id=375183
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=369883
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=337844
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=345009
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=369237
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=340676
18:17:52 T:1644119120 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=412924
18:18:55 T:1465906256   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
18:18:58 T:1963979856  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.15)
18:19:03 T:1644119120   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
18:19:21 T:1440740432   ERROR: Previous line repeats 1 times.
18:19:21 T:1440740432   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                import cProfile
18:19:24 T:1644119120   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/DR1.png
18:19:26 T:1654649936  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.15)
18:20:01 T:1474294864   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/National Geographic (US).png
18:20:03 T:1465906256   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/FX (US).png
18:20:06 T:1474294864   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/Sky Atlantic (UK).png
18:20:11 T:1474294864   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
18:20:18 T:1440740432   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                import cProfile
18:20:19 T:1644119120   ERROR: GetDirectory - Error getting 13
18:20:25 T:1654649936  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.15)
18:20:33 T:1440740432   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                import cProfile
Hi staff! Any idea?
In the Kodi official Forum, the team told me: "Whoever ported kodi to this platform missed some stuff." - "looks like your system is missing some python libraries, causing addons to fail."
Thanks!
Sorry, it's about a BH 3.0.2G image running on Vu+Solo2... BTW the PIL lib is already needed...
Thanks. Cheers.
