Changing streaming(transcoding) ports on VU+DUO2
streamer
Hi,
Is it possible to change the streaming(transcoding) ports of VU+duo2 from 8001(8002) to 80 for example?
I have some ports limitation on my work and can not recieve the stream if it is using ports 8001(8002).
I am using BlackHole 2.0.8.1.
Thank You!
Hi,
I read somewhere here that i can modify these files:
web.py
stream.py
stream.pyo
....and change the default streaming from 8001 to whoever i want?
...is it really possible? Have anyone done it?
I will really appreciate some help here as i can not access my VU from my work due to some port limitation!
Thanks!
Hi,
Thank You!
... What abouit changing the transcoding port within the transcoding plug-in ... ?
R you sure it is the transcoding port that's blocked and and not the http port? Have you set up ddns and correctly forwarded all ports?
