Changing video source on tv with vu+ remote
Panc88
Hi,
I successfully paired the vu+ remote with my Samsung led tv, and I am able to control channel changes, volume and switching on and off with just that remote.
One little problem is still hurting the experience though. I have a boxee box media player attached to a second hdmi port on the tv and when I press the av button on the remote it correctly pulls the tv av menu, which I try and navigate with the cursors, but it won't work. Only option is to keep pressing the av button until I am placed on the correct source and then wait 30 secs until the osd av menu goes away. With the tv remote I am able to navigate to the correct source, confirm with the ok button and the menu would close.
By the way, I have activated hdmi cec option on the tv.
Thanks for your usual support
I solved... My bad, now I correctly setup HDMI CEC and with my Samsung tv remote everything works flawlessly
