Channel changing problem on Solo2
globestone
Hi
Currently I cannot change channels Consecutive. After down or up channel list opening. How can I set channels Consecutive changing?
I also have a SOLO2, and I would like to be able to skip to next/previous channel in the channel list, without the channel list showing. Anyone knows how to make this work?
I will try to explain some more:
When I press the channel + key on my remote, the channel list show. I would like the SOLO2 to not show the channel list, but instead just jump to the next channel.
Anyone knows how to do this (I hope this is actually what thread starter is asking. If not, I am sorry to post in your thread).
angelofsky1980 has already told you, use the left/right arrow buttons, in the centre of your remote control, instead of the up/down buttons.
Download the Pauli Neutrino Keymap 7.50 plugin from the Bh Addons server and with that you can configure the Channel + - keys to do what your wanting.
Ahhh! Thanks Mick12334!
I now tried it, and it works. I was sure that was an answer of what to do after the channel list showed.
I am actually using a Logitech universal remote, but now I know that I need to reprogram channel +/- with "direction right/left".
