Channel Lists
How can I stop my channel lists auto updating?
Using BH 1.6.6 with Vu+Duo
Regards
How channel lists auto updating by it self?
If U mean that after using settings editor programs and U delete some channel , they will come back again after booting the STB,,may be it a base imago default issue!
Will U please give more details!
RgdZ
a911
How can I stop my channel lists updating,I keep deleting a lot of unwanted channels with Dreamboxedit, save and resend to Duo
and a day or so later they are all back again!! On Pli images you can "disable background scanning" so it dose not update the channel lists,is there somehow i can do the same
in Blackhole? Using bh 1.6.6 with vu+ duo. any advice would be welcome.
When your channel list is how you want it in your receiver, load your channel list (lamedb) into an editor called Dreamset.
(Remember to do all of the following for TV, Radio and Data if you want to)
Right-click on the channels and 'select all'.
Right-click on the channels and go to 'set service(s) attribute' and choose 'yes' on 'untouched by SDT'.
Obviously, save the lamedb and send the channel list back to the receiver.
I think you have to restart Enigma2 for the changes to take effect.
If you later want to re-scan normally or let the receiver update the list automatically, perform the above process again first but choose 'no' on 'untouched by SDT'.
Thanks m8,will give it a go and report back
