channel search on remote control - Help please
josephine5899
Hi,
When I open the channel list, I want the numbers on the remote control to scroll quickly. For example, if I’m on BBC, if I press S button, it should go to the channels starting with S – but it does not. Any ideas on this please, or do I have to scroll through hundreds of channels to get to letter S, or T, etc.
Thank you,
yes same here. I`ve never done this or even knew it could be done and I`ve had a Duo and Duo2 for a few years and used BH all that time........
Hi,
Thank you,
You just need to disable EPG buttons in channel list:
Blue Panel > EPG Panel > Global Settings > Enable EPG Buttons in Channel List: NO
