Channel Zapping Tweak
afc_rich
Is it possible to navigate through the channels using the left and right buttons without the STB automatically zapping?
I wish to browse the channels pressing left or right and then press ok to zap the current selection. I used this functionality a lot on my SKY HD box before moving over to the Duo and must say that I am missing it a lot :-(
Any advice on setting this up would be appreciated. Thanks
Try the plugin : Pauli Neutrino Keymap
Green>Yellow>Addons Download Manager> BH Image Plugins
It may fulfill your wishes!
Thanks for the tip, however it doesn't give the functionality required. It only allows you to remap keys to existing functions and I already have Muli QuickButton installed. Any other suggestions folks?
Thanks! Tried VIX last night and it has everything in there that I want. All down to personnel preference but I think I'll stick with VIX for the time being.
