channels list alphabet
frank087234
WHY is there no way to go thru the all channels list by just pressing the corresponding alphabet button??? eg if i want to go to MBC , i could press M while on the channels list
this option is available in openpli, but no BH
The option is available!
You need to disable EPG buttons in channel list,
Blue Panel > EPG Panel > Global Settings > Enable EPG Buttons in Channel List: NO
When you check alphabetically as stated above, and there are several Channels with the same name but obviously on different satellites, is there any indication to easily help you to identify which Channel you actually want to choose?
this means we can not view epg buttons any more
Since which bh version have you made this option???, i am using bh for 2 yrs, and hated it for this reason
Open the channel list (arrow up or down button) and press the Green button (Satellites).
You will see 3 lists for each satellite (Channels - Provider - New);
choosing the Channels list it will be displayed only the channels list of the satellite you have choosen.
Yes but while using alphabetical mode and there are several similarly named Channels, I then pressed Menu Button and OK on "show transponder info". And then I could choose the proper Channel.
But on DM800, using different Images and Skins naturally, as soon as I used to go on a Channel, it instantly showed the relative Sat against each Channel even in alphabetical mode.
