Channels on same transponder info
I agree with Angelofsky1980.
Post your tuners configuration for help.
Remove ALL sat cables Use one cable only (move Cable to all tuner) to verify LNB/Tuner is functioning properly.
Also try to view two different transponders from web interface and TV.
Also use PIP with Different Transponders.
If all above is functioning correctly (This Also means your Tuners functions properly) then
set your recordings path to different media for testing.
Regards. :cool:
It's very strange who tuners A & B doesen't works correctly.
Verify with attention the tuner config: if you use two coax cables (one per tuner) DON'T USE loopback connection in Tuner configuration but "Same As Tuner ....".
I use an SCR LNB with a motorized dish, two SCR addresses and recordings works very good.
Do you have VU Ultimo or Duo?. I use Tuner B as Same as Tuner A but I tried to Simple config type for the Tuner B but the result was same. I use Sharp Quad LNB for 2 pcs 2 tuners STB
I've both boxes: Duo and Ultimo.
You have two coax cables: GOOD!
You should config tuner A with your config and then configure the B with "Same as tuner A" and this should be the correct setup....
Yes this is correct setup for this case. But if I understand well our colleague @bodrogi53 he tried it yet but same result.
Common sense tell me if we have 2 separate tuners with 2 cables on it MUST WORK recording on one transporder and watching or recording on second transporder independent from polarization(V/H).
Yes this is correct, but my unit does not work in this case. It works same as 1 tuner STB. The seller said that the software is not good but I think it is not true because of the STB does not work with neither original image nor four 3rd party images as ex.BH, VTi, VIX, SIF either.
Its a hardware Issue, not software!
Yes, now is clear. You have HW problem because not working on all images.
Please, get back box to the vendor for reclamation.
p.s.
I have fix dish + motor all in one in 1 diseq and 1 tuners, in the future I will make test with my duo to remove 1 cable(motor) from my diseq and put it in second tuner(B).
p.s.
Hi,
THX all!
About what You speak ? For Vu+ duo ? Try what I said above @a911.
I'm talking about twin LNB conected with 2 cables to tuner A and tuner B. This way you can record and watch any channels of 2 different transponders even one with V polarization and other with H polarization. Can anyone can deny this? Of course not.
Hi,
Sorry I cannot agree with you. If you use loop- thrugh method on the 2 tuners box then you can watch and record 2 channels from same transponder in the same time. If you want to recording 2 channels in same time from different transponder then you have to unique cables to the both tuners and at least the twin LNB too.
My problem is that my new Ultimo cannot recording 2 channels from different transponders in same time or I cannot watch one channel and recording an others from different transponder although I have twin LNB and 2 cable to the Tuner A and the Tuner B. Recently I used STB with 2 tuners PVR function and it worked fine, but the Ultimo does not work with same enviroment.
The seller said that the software is wrong but I tried it with Black Hole, VTi, SIF Team, Open PLi 3rd party images and the results were same
Curently I have a very expensive, unsuaable Ultimo names STB. The Ceru Ltd support (distributor) did not response for a week neither via e-mail nor via facebook.
Read my above reply to Dzoni and you will understand.
I'm talking about twin LNB conected with 2 cables to tuner A and tuner B. This way you can record and watch any channels of 2 different transponders even one with V polarization and other with H polarization. Can anyone deny this? Of course not.
Who have a box with twin tuner that don't have 2 cables conected to both tuners (with twin LNB or at least 2 different single LNB)? This don't make sense, because it's not possible to see at same time 2 different transponders with different polarization with just one cable connected.
Yes my friend, we can see and record simultaneously any channel from 2 different transponders on boxs with 2 tuners like VU+ Duo and VU+ Ultimo.
Regards,
biscamax
Hi,
There was not correct if the user use 1 cable to the tuner A and use looptrught mode to the tuner B. Then he cannot see and record from two different transponders in same time
Hi,
Yes, this is correct now
Regards,
biscamax
JUST SEE WHAT YOU WROTE ! You did not wrote nothing about 2 tuners with 2 separate cable connection ! You answered this on post of @a911 and in his post also HAVE NOT anything about 2 SEPARATE cable on 2 tuners, he said about configuration with 1 cable connection and 2 tuners with setting for tuner B (loopthrough tuner A).
All know that we can watch with 2 tuners and 2 cable connection channels from apsolutly different transporder and polarization.
So, please next time read careful before answer me something, because it creates confusion.
Regards !
Regards !
My reply to you (post #30 in this thread) was clear and with no confusions, because you asked me what I was talking about, and I answered you that I was talking about 2 cables, one for each tuner, as simple as that.
I can have done a mistake in my reply to friend a911, because in that reply I did not talked about 2 separate cables, but even with only 1 cable we can see and record 2 channels of 2 different transponders with the same polarization.
this works fine until i try to switch to another satellite then the motor does not move until i change back to loopthrough?!
think i might be better off installing another lead and go direct from LNB for tuner B instead of looping from tuner A....... would this work?? and set tuner B as a second cable from LNB?
