Hi,
Using BH176 on a Vu Plus Ultimo receiver (1TB hard disk), (motorised Quad LNB via VBoxII) with triple tuners (S/S2). Once tuner A is setup, tuner B is set as a loop through, tuner c as a second cable of motorised LNB. The dish is pointing at 19.2E Astra 1, it appears that I am loosing channels being displayed on screen, apart from BBC. I noticed that the flashing Satellite Dish symbol and the viewed channel as no assigned tuner? I have re-programmed the satellite positions of the VBoxII many times, but this has not solved the problem. Why is this happening? Do the tuner drivers need updating or I am missing something out? Does this receiver need a hard reset everytime there are changes to the system, in order to recognise them?
Many thanks in advance, for all your help.
With kind regards,
With kind regards,
