Chiavetta Dtt Hamlet e Pctv 73e
Mich
Buon giorno a tutti, sono nuovo cioè dopo un anno di Vu+ Chip ferrari, ora sono passato alla Vu+ Zero, vorrei chiedervi se è supportata la pennetta Hammet Dtt XDVBT900BK (mi pare di no), mentre la PCTV 73e alle volte va alle volte non viene riconosciuta.
Per la Hamlet serve l'output dello script di debug http://www.vuplus-community.net/board/threads/debug-script-per-le-immagini-bh.21514/
Per la PCTV 73e purtroppo lo appiamo e stiamo cercando una soluzione.
PS: ricordati che il tuo clone qui non è il benvenuto.
Ecco il debug:
Box Info
Kernel: Linux vuzero 3.13.5 #1 SMP Tue Nov 25 03:50:05 CET 2014 mips GNU/Linux
BH Ver: BlackHole 2.1.4
MAC: 00:1D:EC:08:78:9E
USB devices
Bus 001 Device 002: ID 059f:1018
Bus 001 Device 003: ID 1b80:d3a4
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
Kernel Messages
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 315300K/524288K available (6005K kernel code, 277K rwdata, 1160K rodata, 224K init, 114K bss, 208988K reserved)
Hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 751 MHz (375.762 MHz counter)
Calibrating delay loop... 749.56 BogoMIPS (lpj=374784)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
CPU1 revision is: 0002a065 (Broadcom BMIPS4380)
FPU revision is: 00130001
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Initialized.
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource wktmr
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Registering unionfs 2.5.13 (for 3.13.7)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 615
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406800 (irq = 62, base_baud = 5062500) is a 16550A
console [ttyS0] enabled
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406840 (irq = 63, base_baud = 5062500) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406880 (irq = 64, base_baud = 5062500) is a 16550A
loop: module loaded
ahci strict-ahci.0: can't get clock
__clk_enable: sata [1]
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 1.5Gbps
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 87
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 87
brcmstb_nand: NAND controller driver is loaded
__clk_enable: network [1]
__clk_enable: enet [1]
bcm7552_pm_genet_enable 00
bcmgenet: configuring instance #0 for internal PHY
bcmgenet bcmgenet.0 eth0: link down
__clk_disable: enet [0]
bcm7552_pm_genet_disable 00
__clk_disable: network [0]
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
bcm7552_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 2
ohci-brcm ohci-brcm.0: irq 67, io mem 0x10480400
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
ata1: SATA link down (SStatus 0 SControl 310)
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix H27U2G8F2CTR-BC)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x0000025c0000
Creating 4 MTD partitions on "brcmnand.0":
0x000002100000-0x000010000000 : "rootfs"
0x000002100000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
usb 1-1: new high-speed USB device number 2 using ehci-brcm
ata2: SATA link down (SStatus 0 SControl 300)
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi2 : usb-storage 1-1:1.0
usb 1-2: new high-speed USB device number 3 using ehci-brcm
random: nonblocking pool is initialized
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 223 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1779, bad PEBs: 5, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 33/18, WL threshold: 4096, image sequence number: 909094536
UBI: available PEBs: 0, total reserved PEBs: 1779, PEBs reserved for bad PEB handling: 35
UBI: background thread "ubi_bgt0d" started, PID 55
ALSA device list:
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 58
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 219541504 bytes (209 MiB, 1729 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID EA176B21-D9AE-4C69-8202-AF4F7292CA17, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 224K (80748000 - 80780000)
scsi 2:0:0:0: Direct-Access MAXTOR S TM380211AS PQ: 0 ANSI: 2 CCS
sd 2:0:0:0: Attached scsi generic sg0 type 0
sd 2:0:0:0: [sda] 156301488 512-byte logical blocks: (80.0 GB/74.5 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 34 00 00 00
sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI disk
procmk_init
dvb_bcm7362: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_zero_)
bcm7362: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7362 FE)...
Hotplug - status.connected 1:1:2
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
0:0
[DFP]: registered dbox fp
[SC]: registered sci0
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc1
fpga update driver loaded
udevd (118): /proc/118/oom_adj is deprecated, please use /proc/118/oom_score_adj instead.
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1 0
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (244)
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0 0
EXT4-fs (sda1): recovery complete
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Adding 1048572k swap on /hdd/swapfile. Priority:-1 extents:5 across:1081340k
NET: Registered protocol family 10
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
bcmgenet bcmgenet.0 eth0: link up, 100 Mbps, full duplex
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
fuse init (API version 7.22)
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -1386832416
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER : amixl 26, amixr 26
[AUD]: AUDIO_SET_MIXER : next left volume -1927, right volume -1927
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: downmix 0 state : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 2 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[AUD]: AUDIO_CONTINUE 1 1 aph=0xad792c80
[AUD]: Mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[AUD]: Mute : 0
Modules Loaded
Module Size Used by Tainted: P
fuse 88268 2
ipv6 326329 12 [permanent]
ext2 56975 0
fpga_directc 493 0
brcmfb 1590 4
dvb_bcm7362 6597737 26 brcmfb
procmk 1668 1 dvb_bcm7362
Kernel Objects
/lib/modules/3.13.5
/lib/modules/3.13.5/modules.symbols.bin
/lib/modules/3.13.5/modules.ccwmap
/lib/modules/3.13.5/modules.usbmap
/lib/modules/3.13.5/kernel
/lib/modules/3.13.5/kernel/fs
/lib/modules/3.13.5/kernel/fs/nls
/lib/modules/3.13.5/kernel/fs/nls/nls_cp850.ko
/lib/modules/3.13.5/kernel/fs/ext2
/lib/modules/3.13.5/kernel/fs/ext2/ext2.ko
/lib/modules/3.13.5/kernel/fs/fuse
/lib/modules/3.13.5/kernel/fs/fuse/fuse.ko
/lib/modules/3.13.5/kernel/fs/ntfs
/lib/modules/3.13.5/kernel/fs/ntfs/ntfs.ko
/lib/modules/3.13.5/kernel/fs/reiserfs
/lib/modules/3.13.5/kernel/fs/reiserfs/reiserfs.ko
/lib/modules/3.13.5/kernel/lib
/lib/modules/3.13.5/kernel/lib/crc-ccitt.ko
/lib/modules/3.13.5/kernel/net
/lib/modules/3.13.5/kernel/net/802
/lib/modules/3.13.5/kernel/net/802/stp.ko
/lib/modules/3.13.5/kernel/net/llc
/lib/modules/3.13.5/kernel/net/llc/llc.ko
/lib/modules/3.13.5/kernel/net/ipv6
/lib/modules/3.13.5/kernel/net/ipv6/ipv6.ko
/lib/modules/3.13.5/kernel/net/wireless
/lib/modules/3.13.5/kernel/net/wireless/lib80211.ko
/lib/modules/3.13.5/kernel/net/bridge
/lib/modules/3.13.5/kernel/net/bridge/bridge.ko
/lib/modules/3.13.5/kernel/net/mac80211
/lib/modules/3.13.5/kernel/net/mac80211/mac80211.ko
/lib/modules/3.13.5/kernel/drivers
/lib/modules/3.13.5/kernel/drivers/net
/lib/modules/3.13.5/kernel/drivers/net/usb
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_subset.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_eem.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/rndis_host.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/usbnet.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/cdc_ether.ko
/lib/modules/3.13.5/kernel/drivers/net/usb/zaurus.ko
/lib/modules/3.13.5/kernel/drivers/net/tun.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/ath.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170
/lib/modules/3.13.5/kernel/drivers/net/wireless/ath/carl9170/carl9170.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8192cu.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap
/lib/modules/3.13.5/kernel/drivers/net/wireless/hostap/hostap.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/8812au.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187
/lib/modules/3.13.5/kernel/drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/mt7650u_sta.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw
/lib/modules/3.13.5/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt73usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2500usb.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2x00lib.ko
/lib/modules/3.13.5/kernel/drivers/net/wireless/rt2x00/rt2800lib.ko
/lib/modules/3.13.5/kernel/drivers/mtd
/lib/modules/3.13.5/kernel/drivers/mtd/nand
/lib/modules/3.13.5/kernel/drivers/mtd/nand/nandsim.ko
/lib/modules/3.13.5/kernel/drivers/usb
/lib/modules/3.13.5/kernel/drivers/usb/serial
/lib/modules/3.13.5/kernel/drivers/usb/serial/usbserial.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/cp210x.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/pl2303.ko
/lib/modules/3.13.5/kernel/drivers/usb/serial/ftdi_sio.ko
/lib/modules/3.13.5/kernel/drivers/misc
/lib/modules/3.13.5/kernel/drivers/misc/altera-stapl
/lib/modules/3.13.5/kernel/drivers/misc/altera-stapl/altera-stapl.ko
/lib/modules/3.13.5/kernel/drivers/misc/eeprom
/lib/modules/3.13.5/kernel/drivers/misc/eeprom/eeprom_93cx6.ko
/lib/modules/3.13.5/kernel/drivers/scsi
/lib/modules/3.13.5/kernel/drivers/scsi/sr_mod.ko
/lib/modules/3.13.5/kernel/drivers/cdrom
/lib/modules/3.13.5/kernel/drivers/cdrom/cdrom.ko
/lib/modules/3.13.5/kernel/drivers/media
/lib/modules/3.13.5/kernel/drivers/media/rc
/lib/modules/3.13.5/kernel/drivers/media/rc/bh-rc-core.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840
/lib/modules/3.13.5/kernel/drivers/media/i2c/cx25840/cx25840.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/saa7115.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/msp3400.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/tvp5150.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/mt9v011.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/ir-kbd-i2c.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/wm8775.ko
/lib/modules/3.13.5/kernel/drivers/media/i2c/cs53l32a.ko
/lib/modules/3.13.5/kernel/drivers/media/pci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci
/lib/modules/3.13.5/kernel/drivers/media/pci/ttpci/ttpci-eeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-common.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dw2102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cxusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-af9005.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dib0700.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dibusb-mc.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-opera.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-gp8psk.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtv5100.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-digitv.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-a800.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-m920x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-cinergyT2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp7045.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-vp702x.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-nova-t-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-az6027.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-technisat-usb2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-pctv452e.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-umt-010.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb/dvb-usb-dtt200u.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2
/lib/modules/3.13.5/kernel/drivers/media/usb/b2c2/b2c2-flexcop-usb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/cx231xx/cx231xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/as102
/lib/modules/3.13.5/kernel/drivers/media/usb/as102/dvb-as102.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/siano
/lib/modules/3.13.5/kernel/drivers/media/usb/siano/smsusb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/tm6000/tm6000.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828
/lib/modules/3.13.5/kernel/drivers/media/usb/au0828/au0828.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/mxl111sf-demod.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-mxl111sf.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-au6610.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-gl861.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-anysee.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-rtl28xxu.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-lmedm04.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-az6007.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb_usb_v2.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ce6230.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-ec168.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/em28xx/em28xx-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-dvb.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-videodev.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/tuner.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-memops.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/v4l2-common.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/bh-v4l2-common.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-vmalloc.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/v4l2-dv-timings.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf2-core.ko
/lib/modules/3.13.5/kernel/drivers/media/v4l2-core/videobuf-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-core
/lib/modules/3.13.5/kernel/drivers/media/dvb-core/bh-dvb-core.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88ds3103.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/atbm8830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cxd2820r.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ix2505v.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ec100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lg2160.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1x93.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp21.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lnbp22.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp8870.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a16.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib8000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2165.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si2168.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/bcm3510.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/sp887x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6421.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/isl6423.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt312.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dibx000_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s921.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/itd1000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mt352.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda18271c2dd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51132.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/or51211.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10036.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10039.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/l64781.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000m.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib7000p.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dvb-pll.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10021.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10023.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10048.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_dig.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10071.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda10086.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/as102_fe.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda1004x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0288.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0297.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0299.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ds3000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/m88rs2000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/zl10353.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0367.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/si21xx.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/hd29l2.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt200x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24113.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24116.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24117.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx24123.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0070.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1409.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1411.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/au8522_common.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1420.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/a8293.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib0090.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/s5h1432.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tua6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb0899.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/mb86a20s.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2830.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/rtl2832.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ts2020.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/ves1820.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt3305.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stb6100.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22700.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/cx22702.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9013.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9033.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgdt330x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib9000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda8261.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/tda826x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv090x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/nxt6000.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mb.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/dib3000mc.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/stv6110.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxd.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/drxk.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/lgs8gxx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners
/lib/modules/3.13.5/kernel/drivers/media/tuners/m88ts2022.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt20xx.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc2580.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5005s.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mxl5007t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18212.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18218.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda18271.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tua9001.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-xc2028.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-simple.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/max2165.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mc44s803.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/r820t.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5761.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tea5767.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/e4000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/qt1010.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0011.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0012.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/fc0013.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda9887.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner_it913x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2060.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2063.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner-types.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda8290.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2131.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tda827x.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/xc5000.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/mt2266.ko
/lib/modules/3.13.5/kernel/drivers/media/common
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2
/lib/modules/3.13.5/kernel/drivers/media/common/b2c2/b2c2-flexcop.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cx2341x.ko
/lib/modules/3.13.5/kernel/drivers/media/common/cypress_firmware.ko
/lib/modules/3.13.5/kernel/drivers/media/common/tveeprom.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsmdtv.ko
/lib/modules/3.13.5/kernel/drivers/media/common/siano/smsdvb.ko
/lib/modules/3.13.5/kernel/drivers/staging
/lib/modules/3.13.5/kernel/drivers/staging/zram
/lib/modules/3.13.5/kernel/drivers/staging/zram/zram.ko
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712
/lib/modules/3.13.5/kernel/drivers/staging/rtl8712/r8712u.ko
/lib/modules/3.13.5/kernel/drivers/staging/winbond
/lib/modules/3.13.5/kernel/drivers/staging/winbond/w35und.ko
/lib/modules/3.13.5/kernel/drivers/staging/media
/lib/modules/3.13.5/kernel/drivers/staging/media/omap24xx
/lib/modules/3.13.5/kernel/drivers/staging/media/omap24xx/v4l2-int-device.ko
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng
/lib/modules/3.13.5/kernel/drivers/staging/wlan-ng/prism2_usb.ko
/lib/modules/3.13.5/modules.dep
/lib/modules/3.13.5/modules.isapnpmap
/lib/modules/3.13.5/modules.ieee1394map
/lib/modules/3.13.5/extra
/lib/modules/3.13.5/extra/brcmfb.ko
/lib/modules/3.13.5/extra/fpga_directc.ko
/lib/modules/3.13.5/extra/dvb-bcm7362.ko
/lib/modules/3.13.5/extra/procmk.ko
/lib/modules/3.13.5/modules.dep.bin
/lib/modules/3.13.5/modules.devname
/lib/modules/3.13.5/modules.inputmap
/lib/modules/3.13.5/modules.seriomap
/lib/modules/3.13.5/modules.softdep
/lib/modules/3.13.5/modules.alias
/lib/modules/3.13.5/modules.pcimap
/lib/modules/3.13.5/modules.ofmap
/lib/modules/3.13.5/drivers
/lib/modules/3.13.5/drivers/net
/lib/modules/3.13.5/drivers/net/wireless
/lib/modules/3.13.5/drivers/net/wireless/rt5370sta.ko
/lib/modules/3.13.5/modules.alias.bin
IFConfig output
eth0 Link encap:Ethernet HWaddr 00:1D:EC:08:78:9E
inet addr:192.168.0.115 Bcast:0.0.0.0 Mask:255.255.255.0
inet6 addr: fe80::21d:ecff:fe08:789e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4112 errors:0 dropped:2 overruns:0 frame:0
TX packets:2334 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:489415 (477.9 KiB) TX bytes:607486 (593.2 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:86 errors:0 dropped:0 overruns:0 frame:0
TX packets:86 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:7548 (7.3 KiB) TX bytes:7548 (7.3 KiB)
IWConfig output
WLan Scanning - WLAN device
--> WLAN0 interface
WLAN0 - scan
WLAN0 - channel
WLAN0 - rate
WLAN0 - encryption
WLAN0 - power
WLAN0 - wpakeys
WLAN0 - auth
--> WLAN1 interface
WLAN1 - scan
WLAN1 - channel
WLAN1 - rate
WLAN1 - encryption
WLAN1 - power
WLAN1 - wpakeys
WLAN1 - auth
--> WLAN2 interface
WLAN2 - scan
WLAN2 - channel
WLAN2 - rate
WLAN2 - encryption
WLAN2 - power
WLAN2 - wpakeys
WLAN2 - auth
WLan Scanning - RA device
--> RA0 interface
RA0 - scan
RA0 - channel
RA0 - rate
RA0 - encryption
RA0 - power
RA0 - wpakeys
RA0 - auth
--> RA1 interface
RA1 - scan
RA1 - channel
RA1 - rate
RA1 - encryption
RA1 - power
RA1 - wpakeys
RA1 - auth
--> RA2 interface
RA2 - scan
RA2 - channel
RA2 - rate
RA2 - encryption
RA2 - power
RA2 - wpakeys
RA2 - auth
DNS settings
Dumping /etc/resolv.conf ...
nameserver 8.8.8.8
nameserver 8.8.4.4
Routing Table
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
169.254.0.0 * 255.255.0.0 U 0 0 0 eth0
192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
Ecco il debug:
Box Info
USB devices
Kernel Messages
NR_IRQS:160
Brought up 2 CPUs
FS-Cache: Loaded
loop: module loaded
ALSA device list:
UBIFS: parse sync
devtmpfs: mounted
sda: sda1
procmk_init
[GP]:brcm_pwm_init
[LCD]: registered
0:0
FE tune
[AUD]: Mute : 0
[AUD]: Mute : 0
Modules Loaded
fuse 88268 2
ext2 56975 0
fpga_directc 493 0
brcmfb 1590 4
Kernel Objects
/lib/modules/3.13.5
IFConfig output
IWConfig output
--> WLAN0 interface
WLAN0 - scan
WLAN0 - channel
WLAN0 - rate
WLAN0 - encryption
WLAN0 - power
WLAN0 - wpakeys
WLAN0 - auth
--> WLAN1 interface
WLAN1 - scan
WLAN1 - channel
WLAN1 - rate
WLAN1 - encryption
WLAN1 - power
WLAN1 - wpakeys
WLAN1 - auth
--> WLAN2 interface
WLAN2 - scan
WLAN2 - channel
WLAN2 - rate
WLAN2 - encryption
WLAN2 - power
WLAN2 - wpakeys
WLAN2 - auth
--> RA0 interface
RA0 - scan
RA0 - channel
RA0 - rate
RA0 - encryption
RA0 - power
RA0 - wpakeys
RA0 - auth
--> RA1 interface
RA1 - scan
RA1 - channel
RA1 - rate
RA1 - encryption
RA1 - power
RA1 - wpakeys
RA1 - auth
--> RA2 interface
RA2 - scan
RA2 - channel
RA2 - rate
RA2 - encryption
RA2 - power
RA2 - wpakeys
RA2 - auth
DNS settings
nameserver 8.8.8.8
nameserver 8.8.4.4
Routing Table
Hai un device Realtek rtl2832 non menzionato nei driver. Verrà aggiunto appena possibile.
