Request CIFS not mount if STB boot before PC
VU PLUS Solo2
Hi,
I setup a CIFS share to record on my PC and almost everything is fine but I have a problem that my SOLO2 wants mount shared folder every time after boot and if I boot windows on my PC after Enigma 2 and I press record button it says " No HDD found or HDD not initialised!" and I have to mount folder manually or restart Enigma 2.
is there any option or plugin or others that help me it mount automatically af
Hi,
It's a CIFS limitation. If you can, use NFS shares.
I don't know why my last sentence is broken. it was like this:
is there any option or plugin or others that help me it mount record folder automatically after I press record button?
Thank you my friend.
I tried today with "haneWIN NFS Server" but I couldn't mount NFS in my VU+.
Did you test NFS share already? if yes, how?
IP must be same pc IP like CIFS?
"Server share" must be folder name?
Do you have any guide?
I use ONLY NFS shares from my Synology NAS.
I've always used the last option from Blue Button Menu (2 x blue) to mount NFS shares and it's quite easy.
About IP, must be the IP of your NFS server
About server share is the logical NFS path, but the mount manager scans the network for you and you should get the mount in minutes. Be sure to answer NO when the box asks if the server requires username/password that usually is not needed for NFS that uses IP for grant access to shares.
Thanks for your reply.
I think Synology NAS is a extra device, right?
Can you please help me to setup nfs server on my Windows 10 from 0 to 100?
You are right: Synology NAS is extra hardware with disks that shares media content in my house.
I've never setup NFS server on Windows, sorry.
