Clone OMB from USB to ssd
valery84
Hi, I will mount an ssd on duo 4k se. I wish to clone all omb images and config actually on USB pen, on new ssd and finally remove USB. Is there anyone who ca help me? Thank you
I have never tried it, but I think if you mount the sdd and the usb you should be able to copy the openmultiboot folder from the usb to your ssd.
Then remove the usb (but don't delete the files just incase).
Reboot the box, and then open the openmultiboot plugin and it should ask where you want to install, select hdd (or whatever you have mounted the ssd as).
Then hopefully your images will show and boot as normal.
Yes it's possible, it's done! I installed OBH 5.0.001 in the OMB, without resorting to the backup that had on the disc (OBH 4.4.023), installing everything again, after then I installed it in flash (Uno 4KSE).
Using backup looks bad idea... It was what I did initially and gave problems... perhaps the question of plugins. I only have two incompatible plugins, one of them is fundamental and while not adapted to Duo 4K will continue with 4.4.023.
Maybe someone who can move in this plugin....
