Common Interface
Seems compability problem SMIT IRDETO CRW access problem.When I use @SMIT SECURE PLUS IRDETO CI+ modul work at restart ok....
What is the actual status of supported CAM modules? Where i can find an updated list of supported CAMs?
here is a update of my CAM collection in the Vu+Uno
NB all cams have been tested and are working in my DM7020
ORIGINAL CAMS
seca aston black rev 1.03 NOT DETECTED
viaccess black rev 1 NOT DETECTED
irdeto FULLY WORKING
conax ( technicrypt ) FULLY WORKING
magic / special cams
dragon module rev 2.06 with loader card ( predator 3.69 updated to pred 3.80 with loader card in Uno ) FULLY WORKING
dragon module rev 3.02 ( firecrypt ) = damaged body ( predator 3.69 updated to pred 3.80 with loader card in Uno ) FULLY WORKING
diablo (1) light rev 2.2 upgraded to 2.3 via software patch ( underworld 2.14 ) FULLY WORKING
diablo (1) light rev 2.2 ( not updated still 2.2 ) ( underworld 2.14 ) FULLY WORKING
icecrypt blue rev 2.01 NOT DETECTED
zeta red rev 2.01 NOT DETECTED
matrix reloaded ( mr 1.082 ) FULLY WORKING
matrix revolutions ( mrv 2.24 ) FULLY WORKING
i should have a Viaccess red cam ( early generation ) and a seca aston v 1.04 coming soon, i will test those and update this thread.
a few minor updates and alterations
ORIGINAL
irdeto 2 ( loader ver 3.1 / softcell ver 2.26D ) FULLY WORKING
conax ( technicrypt - technisat cx ) software ver 26.1.5.0.6 interface ver 0x40 FULLY WORKING
dragon madule rev 3.02 ( firecrypt ) = damaged body ( predator 3.69 updated to pred 3.80 with loader card in Uno ) FULLY WORKING
zeta orange rev 2.01 NOT DETECTED
matrix reloaded ( mr 1.082 ) HW 1.5 / loader 1.0 FULLY WORKING
matrix revolutions ( mrv 2.24 ) HW 1.5 / loader 1.0 FULLY WORKING
I have problem with reading entitlements, I do not see complete end dates on right. Where to change size of smartcard's window? It is very small.
Dear Friends:
My VU SOLO2 receiver has a CAM interface , but it can descrambled the channel .and I use the same CAM card to try it with another receiver , it can descrambled the channel , why ? how do somebody can tell me ? thanks
der guys,
I have a problem VU DUo reveiver. I bought Irdeto card but receiver doesn't read the card. I am using Black Hole 2.0.5 Rev B and kernel 3.1.1.
Do you have any idea of the setup, any parameter or software?
Many thanks,
der guys,
Many thanks,
Sure. Buy a CI CAM for your CA system (Irdeto).
