Configuring Duo Tuner for additional satellite dish
j-fm
Hi,
I want to add an addition dish with a DiSEqC. I've checked signals from both dishes and they work seperately but I cannot configure the tuner to work with the DiSCEqC switch. I'm using Ope BH.
Please can someone tell me how to do it?
Thanks
Just set your tuner to DISEqC A/B, or DISEqC A/B/C/D, depending how many LNB's you have working.
Menu, Setup, Tuner Configuration, Tuner Setup.
If you have any problems please post back with more detailed information.
OK thanks Mick, I'll try that when I put the switch back. Its too hot here to do at the moment 40°C
