Connect problem
ertan3
In OBH 4.3 solo2, the dream edit / settings verify the ip address, but the connection does not take place. Likewise Flashxp does not connect. But I can connect to the device from the windows network.
Are you talking about dreamboxedit?
Have you gone into Tools, Options, typed your IP Address, tested the connection, and remembered to click save, on exiting?
What error message do you get when going into File, and Fast FTP download?
Solo2 flash also has BH3.0.9 multiboot installed on OBH4.3. Dream edit IP check "http://xxx.xxx.x.xxx connected via port 80" user and password check "http://xxx.xxx.x.xxx failed to connect from port 21, check IP address and por no" , Flashxp "connection failed / connection refused" I get the message. However, the connection from the windows network is taking place.
yes yes yes
same problem for me on OPENBH images on vusolo2
i think another people also have this problem
connection with DreamboxControl Center Via FTP is failing and not connect (TELNET : Connected FTP: not Conneccted ) and when i try going to ftp tab that instantly appear ETC folder ( should be VAR )
there is a important problem VU SOLO2 windows 10
another Images tested no problem with each other images !!
only this OPEN BLACK hole have problem and for this problem i totaly forgot and remove BH images and im using another images about 3 years
I think the problem is Windows or the software you use: surely not BH or OBH. I've been using ALL BH and OBH releases since years and never had FTP issues.
Before doing such apocalyptic claims, you should cleverly think that there is only a few messages about that. If it were a general BH or OBH problem, we would be overwhelmed by similar messages.
