Hello,
After a long time I flashed new Open BH 0.14 version for Vu+ Duo2 imidge and can't login any more to webif from external ip. When I enter ip address and port it opens connection table but doesn't accept login data. In old image it was possible to connect from external ip without http authorization and the new one without authorizations allows to connect only from internal ip. If I enable http authorization it doesn't accept default root login and empty pass entries. Can it be that external connection is automatically blocked with empty password? Is it possible to set password over some plugin or ftp connection or only telnet?
Thank you!
Thank you!
