Consultation of the remote control VU+ Bluetooth RCU (BT100 RCU).
Tururu
BH Lover
In this command we have a key that in theory activates a microphone, in the photo it is marked and where the microphone is installed.
As such, it has no function in the receivers currently, tomorrow who knows, I don't.
In the new IR300 brown model, I don't know if the electronics are there, the day I have to open, I'll see.
The new Bluetooth RCU model (BT100 RCU) if they have the electronics.
I'm curious to see the option marked and see nothing/no documentation and looking for searching .....
In theory it is to give voice commands to (voice search).
Do not put any object through the "orifice" of the micro, you can easily damage the membrane of the micro type electer/condenser to see if it has/is underneath.
Specifications Vu+ Bluetooth RCU (BT100 RCU):
- MCU: RTL8762A
- Communication: BLE 4.1
- Key: 46EA
- Function: UR TV, Voice Search
- Indicator: LED 1EA (RED)
- Batteries: AA x 2EA (alkaline)
- Firmware update: OTA
Who had a team that supports voice commands (Alexa/Echo/etc.), Who can see if you can "pair" this Bluetooth device and tell us how it works and if it works.
Yes, I know, there are many ISIs, having a team that supports voice commands and then having the Vu+ Bluetooth RCU (BT100 RCU), but who knows, the world is very big.
To activate/to present yourself, press the MENU and AUDIO keys at the same time, the deco will find it within 5 seconds, like all equipment, it is identified by the unique MAC in all communications equipment.
In these teams, look, luck.
PS: In Spanish for me.
En este mando tenemos una tecla que en teoria activa un micro, en la foto esta marcada y donde esta instalado el micro.
Como tal, no tiene ninguna funcion en los decos/receptores actualmente, mañana quien sabe, yo no.
En el nuevo modelo IR300 marron no se si esta la electronica, el dia que toque abrir, lo vere.
El nuevo modelo Bluetooth RCU (BT100 RCU) si tienen la electronica.
Me pico la curiosidad al ver la opcion marcada y no ver nada/ninguna documentacion y buscando buscando.....
En teoria es para dar ordenes por voz a (busqueda por voz).
No meter ningun objeto por el "orificio" del micro, se puede dañar facilmente la membraba del micro tipo electer/condensador para ver si lo tiene/esta debajo.
Especificaciones Vu+ Bluetooth RCU (BT100 RCU):
- MCU: RTL8762A
- Comunicación: BLE 4.1
- Clave: 46EA
- Función: TV UR, Búsqueda por voz
- Indicador: LED 1EA (ROJO)
- Pilas: AA x 2EA (alcalina)
- Actualización de firmware: OTA
(Alexa/Echo/etc.), que mire si puede "emparejar" este equipo Bluetooth y nos cuente que tal y si funciona sobre todo.
Si lo se, son muchos ISI, tener un equipo que admita ordenes de voz y luego tener el mando Vu+ Bluetooth RCU (BT100 RCU), pero quien sabe, el mundo es muy grande.
Para activar/para presentarse, pulsa en el mando las teclas MENU y AUDIO a la vez, el deco lo encuentra a los 5 segundos, como todo equipo, lo identifica por la MAC unica en todo equipo de comunicaciones.
En estos equipos, mira, suerte.
PD: Como siempre se admiten errores, de estos temas no tengo ni idea², pero no soy el unico, suerte.
