Cool thanks guide
valb
After using black hole since version 2.0.2 until 3.0.8 I thought I would give OBH a try. I flashed the image and ran an online update.
Everything seems to be working fine but I just can't see where I can download cool tvguide. I think I have tried every point on every menu but just can't find it.
Would someone be kind enough to point me in the right direction?
Regards
Valb
Right decision but, if you want my advice (just not to download plugins not needed) why don't you use directly the MultigraphicEPG?
In OBH you can also easily assign to almost every k_eys the function you wish.
For instance, I assigned to the EPG key just the multigraphicEPG. I find it more elegant and less invasive than CoolTVguid. I mean, it's perfectly integrated in the image and prompts you with the same kind of EPG.
Thanks for your suggestion. I'll give it a try but after using cool TVGuide for so many years it might take some time for me to get used to it.
Old habits die hard!
